ecu? under rear window
geoff64 (09-29-2013)
Thank you Grant ,
but now am even more confused , haha ,
i disconnected it just to eliminate all non essential systems from the electrics and the dash failed to power up at all , no warning lights , check lights or anything . it would appear that it does a bit more than just the sound and phone system .
I don't have premium sound either, but this is the amplifier: JAGUAR XJ6 X300 HARMON KARDON OE UPGRADE AMPLIFIER | eBay. It appears to have Harmon Kardon written on it and a finned top, so it should be pretty recognisable.
What I do have is a Nokia GSM system, which is connected to an aerial on the rear screen. That's equally identifiable from the labels.
But, neither of which should cause your electrics to fail if unplugged. The battery is in the boot, so if you pull or the carpet out does the wiring give any clues? Are there any labels on this mysterious item? How far through the loom to the voltages get?
no, i hav4e had numerous problems with the immobiliser , could find that one with my eyes shut , haha , this one is just off centre , above the fuel tank , and has a multi pin connector that plugs into it , through the metalwork , which is locked in with a lever arm lock type plug . you cannot see the unit , i assume you would have to remove the rear parcel shelf to get to it .
99xk8guy
06-05-2023 06:28 AM
