Electrical problem
Electrical problem
Hello! Just had my jaguar (x300 95 3.2 EU version) repainted and after it came back from shop bunch of electronics had stoped working, including;
Any advice on how to approach this problem would be appreciated.
- trunk does not open with button on it, but work with button from dashboard.
- blinkers are working but super fast
- dash board show 0 mpg current and fuel 0, but shows range correctly
- screen washer fluid sprayer
under the car on all 4 corners there is a black square 13 wire connector that gets corroded , this effects the direction blinkers
your washer pump wires go through the right front under connector
the trunk release outside button wires pass through a cover on the cars right trunk curved hinge arm that has a history of rubbing under the cover
