Electrical problems
Here is what is happening.
While driving both low beams would turn off randomly or not work from the start. Eventually they turn back on after 3-10 minutes. At the same time my headlights turn off, my turn signals stop working and I noticed that my car seat heater switch does not illuminate when I push in the switches. In the daytime I have the same problem (no turn signals) and if I turn on my headlights they do not work. There is a ding-ding-ding sound that is coming from below/behind my dashboard only some times.
This only started after it started getting cold in my area (25-40 degrees Fahrenheit). After my car has been driven a while (after 30 minutes) the problem seems to go away.
Tomorrow I plan on looking at the fuses and relays. Any ideas what may be the problem other than driving a 25 year old car that has many many grounds. There must be something that connects all this!
Thanks,
Jomo
Thanks,
Jomo
Parker 7 (12-22-2021)
Recommmend focusing on the headlights first and the other issues may fall in line
See aage 107 of the 96 wiring guide
The british use the terms
Main = High ?
Dip = Low ?
Pilot = small courtesy light bulb
and I can never keep them straight in my head
Someone correct me on the above if I have them crossed
The pairs of lights use the same ground stud
With the Main you have a dedicated large relay and the power source through the relay is fuse # 2 / 15 amp Right engine fuse box , hot at all times
With the Dip you have a dedicated large relay and the power source through the relay is fuse # 4 / 10 amp Left engine fuse box , hot at all times
The fuse and relay map is here between page 17 and 23
X300 1996 LWB.pdf (jagrepair.com)![Icon Dance Disco](https://www.jaguarforums.com/forum/images/smilies/icon_dance-disco.gif)
A quick note on the control of the lights is a history of some wires coming loose on the stalk switch
Can be resoldered
There are pics
Main = High ?
Dip = Low ?
Can be resoldered
There are pics
jomo (12-22-2021)
grussell
08-05-2023 02:15 AM
