Emergency Brake Light staying on
Recently noticed my emergency brake light stays on after the brake is off and it flickers as I'm driving. It doesn't flicker in a specific pattern but it just does at odd times. Any clues on what this could be....also I checked the brake fluid level and its full. Thanks
Your handbrake switch is either loose, or failing. It's a simple contact switch held in place by 2 phillips screws with 2 wires, so first lift up the handbrake leather boot and have a looksy. If you're lucky it'll be jiggly and a half turn with a screwdriver will fix all. If you're unlucky, that piddly little bugger will set ya back $75 (or you could just unplug it
Part # -LNA6531AA
![Icon Idea1](https://www.jaguarforums.com/forum/images/smilies/icon_idea1.gif)
Part # -LNA6531AA
![](https://www.jaguarforums.com/forum/attachments/xj-xj6-xjr6-x300-26/47453-emergency-brake-light-staying-sj5643.jpg?dateline=1373172647)
99xk8guy
06-05-2023 06:28 AM
