Engine ECU Problems
Engine ECU Problems
I have had multiple issues with my Engine ECU getting wet and water seeping into the the connection. One of the prongs in the computer connection is broken... Now, my 1997 Jaguar Xj6 VDP just recently didn't start and i noticed that in the ECU. Can anyone help me with this issue?
Also, if i was to purchase a new computer, i notice that the codes vary depending on vehicle; is there a way to program a ECU to match mine?
Please help!
Thanks for any answers you may have
Please help!
After getting the correct ECM, I would fabricate a plastic "tent" to shed water around the ECM first, then I'd go hunting for the source of the ingress.
Cheers,
Andy Stodart a ex-Jaguar engineer, Northampton, United Kingdom states he can reprogram any 300x ECU - so I am getting that the basic units are the same except for the removable EPROMs which tell the unit what car is attached. I would also assume you could buy any unit and put your chips in - it should work properly.
Cadillac (10-26-2011)
Please help!
Please help!
Appearantly, the old ECU.s can be fixed by simply fitting a new connector. I have not purchased my connector yet, but intend to do so to have a second working ECU, just in case :
Here is a very informative write up from a gentleman from England :
Jaguar XJ6; Jaguar X300; Jaguar XJ6 3.2 Sport; Engine Control Unit problems; ECU
BrentGardner
28
04-26-2024 03:08 AM
