Engine idle high and rough
I won't be much help but sensing a bit of urgency I thought I'd offer a reply until someone better comes along
Enter P0727 into the search box at the top of the page. I know the subject has comes up previously. The code relates, I think, to an engine speed vs road speed discrepancy...or something like that. Perhaps to be expected if the idle is stuck a 2000 rpm?
Common faults causing a high idle are the idle air control valve (I think Jaguar uses a different name...my mind is drawing a blank) fault and/or a dirty throttle body.
Others will chime in
rachelstr
09-03-2015 01:59 PM
