Engine shakes ONLY IN PARK, please help, thanks.
hi everyone.... I own a 1996 XJ6, and my car "ONLY" shakes in park. When I open the hood, I can see the engine shaking causeing the car to shake. But I cannot figure out why, because I had my engine mounts done about a year ago, anyone else know what it can be? Thank for your help.....
Received 10,913 Likes
Fairly common problem. Mine does the same in "P". Drop it into "D" and it runs smooth.
You probably have an injector that isn't responding to minimal pulse rate command.
At idle in "P" there is very little load on the engine and the injectors are commanded to stay open for a very short period, or short "pulse width". Sometimes an injector doesn't respond to a low command and just stops working.
MC36
US Lower Atlantic
09-01-2015 07:34 PM
