engine swap 95-97 questions.
Looking at the diagram I'm thinking it may be the supercharger bypass actuator. Does this sound right? And if so what does it do? I've noticed that there's no hose coming out of the back of it either..
-Dayn.
EDIT: I was looking at the wrong thing on the diagram it's not the sc bypass valve. I'm still not sure about the original part in question. I'm thinking maybe it's for a harder feel on the gas petle, or maybe an idle adjust?
-Dayn.
Xjengineer I think u may be correct. There are no wires or anything going to it.. What does this thing actually do? As I see it there's no way for it to do anything unless the nut is tightened.. Maybe I'm confused haha.
-Dayn
EDIT: I found the vaccume line that conects to the cruise controll actuator, I think I understand it now. This must suck in the actuator thus moving the throttle correct? Also on the vacuumed pump there is a line missing and it wasn't there when I began. It's the one towards the rear. The smaller line is hooked up but the larger one is missing. Any clue? Thanks again.
Dayn.
-Dayn
Dayn.
well ive finished putting everything back together and now have some codes. the engine starts but is misfiring bad.. ive got codes p306 and p305 so its misfiring on cyl 5 and 6. there are also a few more codes.. p1199, p1775,p1316, and p1314. any help or suggestions are are welcome. thanks.
Dayn
Dayn
