engine swap
Not sure about ECU's etc. although strangely enough, the throttle body is exactly the same. I suppose the difference is in how they are "instructed" by the cars computer.
Not sure of any other major differences off the top of my head. I have a 3.2 donor, so the above main bits aren't a lot of use to me as my daily driver is a 4.0 litre.
The hydraulic only ZF4HP22 gearbox from the 3.2L will cope with the performance of the 4.0L engines and would therefore make the change easier than fitting the electronically controllled ZF 4HP24E from the 4.0L car, as you would also need the gearbox harness and transmission ECU.
