"ER" in ac temperature screen with beeps
The AC Panel has a self diagnostic capability.
The procedure for retrieving the codes involves pressing buttons and observing the panel lights and display. The procedure is described in the Electrical Diagnostics section of the manual which is available for download via the How To Quick Links page.
Here's the process in summary
- Switch off the ignition.
- Press and hold the 'Auto' and 'Fresh / Recirc.' buttons simultaneously, and switch on the ignition.
- All the control panel LED's and all LCD segments will flash on and off. Any function LED indicator which does not flash on / off suggests a fault condition within that area of the panel, or with the LED.
- Any LCD element which fails to flash on / off indicates a fault within the panel or display element.
- Press 'Auto'.
- Press 'Face' to scroll through a maximum of 5 fault codes.The control panel display will flash repeatedly indicating a list of two digit numbers (refer to following page for code analysis).
- If, when a code is displayed, an accompanying 'beep' is emitted, the indicated fault is current and therefore still present within the system. A code displayed without an accompanying 'beep' indicates a fault had previously occurred but is not present within the system.
- To delete stored and cleared fault codes simultaneously press 'HRW' and 'FACE' switches.
- After investigating and correcting all stored faults, press the 'Push Off' button to restore normal operation with default panel settings, ie AUTO at 24°C.
The following 3 users liked this post by b1mcp:
- Press 'Auto'.
24
44
Look it up in the download and
12 is the Ambient Temp Sensor - I'm assuming this would be fixed by replacing the unit?
23 is the Refrigerant dual pressure switch - I'm not exactly sure how much refrigerant is in the system. But where is this switch located exactly?
24 is Face vent differential temperature control - I'm not exactly sure what this means exactly...
44 is the Defrost servo - Also this one, I'm not sure what this means
Finbarr1975
09-16-2023 03:52 PM
