Err and not the Air Flow
Today I swapped out my manifolds for ceramic-coated manifolds and replaced all the O2 sensors. I only ran into one issue where the metal lines that go into the manifold, one connector got stripped out. I was able to get the problem temp fixed until I get another one. So everything went well...so I thought. After replacing it, I figured I would go burn out all the excess coating, started the car and I received the "Err" on my climate control. So I figure maybe the cabin air flow sensor went bad. Replaced it and the same thing. What causes this other than the cabin airflow? I did have the bumper removed to get painted but when I picked it up I did not get that error unless something got loose on the way home. Any ideas?
By the way no other fault codes
osyris
01-15-2022 10:21 AM
