Error Codes
Hello Ronniels,
From my checking I have found the following:
Code 11 is the in car temp sensor fault
Code 23 is refrigerant dual pressure switch fault
Code 32 is the fresh / recirculated air sensor
The in car temp sensor is located on the panel under the steering wheel, almost directly above the emergency brake. There is a small 1-1.5 inch square grill there. If you remove the panel you will see that there is a sensor and a fan motor behind it. The service manual shows how to test this along with the refrigerant pressure switch.
There is a similar post here that you may want to read that has additional details: https://www.jaguarforums.com/forum/x...nations-57257/
KarimPA
09-27-2015 08:46 AM
