Error P1621
Old 09-26-2011, 02:13 PM
Car-Nut's Avatar
Question Error P1621
A friend connected a cheap error code machine to my X330
at the week-end it through up:
P1621
He didnt know what it meant, does any one here
Old 09-26-2011, 02:33 PM
Simprof's Avatar
fault code p1621 on jaguar x300 6 cylinder, means engine imobilization input circuit malfunction?
Not sure if it's the same on the 330
Old 09-27-2011, 04:19 AM
Car-Nut's Avatar
Excuse my lack of knowledge here, but whats the fix then?
Old 09-27-2011, 08:30 PM
Simprof's Avatar
Now that's a good question..
Old 09-28-2011, 03:23 AM
Car-Nut's Avatar
Your mission for today is to find the answer
Old 09-28-2011, 04:40 AM
sparkenzap's Avatar
Received 1,064 Likes on 867 Posts
Car-Nut:
Since cars imported to ourr side of the pond do not have such a circuit, I have no specific experience. BUT my general advice would be to reset it and see if it comes back before I worried about it further. That is, of course if the car starts and runs fine, as I believe you implied.
BTW, none of my OBD code lists specific to the MY '97 X-300 show that code. (JTIS, Alldata) My general code description flist or Jaguars is exactly as Somprof said.
Old 09-28-2011, 09:00 AM
Simprof's Avatar
I agree just do a reset and see if the code goes away, however, if the check engine light is not on and the car starts and runs it may be a code that has not been cleared I know that sounds strange but on my 97 XJR I had two show up on the first scan I did when I bought the car one was an oxygen censor I forget the other, long story short I had NO check engine light and the oxygen censor was new so I know there was nothing wrong with it but they showed up on my OBD11 scan tool so I cleared them and that was all that was needed.. Without doing the scan I would never have known.. I'll make you a deal when I travel back home to Lancaster, Lancs next year I'll come and check it out for you. Mind I'll need the loan of the e-type... :icon_ razz:
Old 09-29-2011, 01:40 PM
Car-Nut's Avatar
My Jags are available for hire check out my footer...
Old 09-30-2011, 12:33 PM
Simprof's Avatar
I did they look great...
ricwel
06-23-2023 05:14 PM
magmedia
08-15-2019 08:54 PM
jimforrest (uk)
02-28-2019 06:42 PM
Poet
10-02-2015 09:00 AM
Collector1
09-28-2015 03:52 AM
Quick Reply: Error P1621
