Exhaust down pipe 3.2l engine 1995 help
Hi, I need one of these, my garage says part number is 380900, people tell me that's not a Jaguar part number... anyway they are discontinued and I'm struggling to get one... anyone have one I can have? or help me find the real part number? the car is a 3.2 litre straight six from 1995
No, that's not a Jaguar part number. Here is the listing page for Jaguar classic parts: https://parts.jaguarlandroverclassic.../brand/jaguar/
The part number you want is either NBC6711FB (spherical joint) or NBC6711CC (slip joint)
There are two types of joint on the end of the down pipe, one slides over the other pipe and the other used a metal ring to seal and the pipe ends flared out. You'll have to match whatever type you have on the rest of your exhaust system, or modify the mating pipe.
What country are you in? I can't really suggest where to get one without knowing where you are. Since 3.2 cars never came to Canada or the USA I'm guessing UK?
Off the top of my head the 3.2 and 4.0 have the same downpipe and is 60 mm after they both come together into a single pipe
But I can be wrong on a 3.2 version
A U shaped clamp that is flat in cross section so it fits in the limited space between the pipe and the floor pan is from Audi but I don't have a part #
Referencing the Jaguar Classic Parts website above which item # is it in the diagram ?
Thank you! great info
I’m in the UK
I’m in the UK
Parker 7 (01-06-2022)
For used parts ( probably all you'll find now) try Eurojag in Darlington. https://www.eurojag.com/. You might have to call to see what they have.
There is one on Ebay now: https://www.ebay.co.uk/itm/154769220...8AAOSw989hD7tn
Kaeghl
05-16-2017 09:08 AM
