exhaust issue1
Guest
Posts: n/a
it might be either your primary or secondar mufflers, because the cats combine again into a single pipe, from the intermediate pipes I assume, then it splits after the cats into the true dual exhaust, through the primary mufflers over the rear axle, then through the secondary resevoirs under the trunk. It's a long road with lots of crawling on the ground to find the problem. Start by taking off the secondaries, and just put your hand up there to feel for pressure. Then just work your way back. I have the same problem with my '95 XJR, there's almost no pressure out of the left side pipe.
FS[SouthWest]: Adamesh X350 Exhaust Tips
XJ8JR
10-02-2015 12:13 AM
baskervillema
10-01-2015 06:43 PM
