Exhaust Tips Again
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
This time not cleaning.... ![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
I set to work removing the old ones undid the grub screw thing, gave them a good knock all round where i could reach then tried to knock them off putting an old screwdriver on the lip and whacking the screwdriver with a lump hammer ..... No joy![Icon Hyper](https://www.jaguarforums.com/forum/images/smilies/icon_hyper.gif)
Tried put penetrating oild down between the pipe and the old chrome tips left it a day, gave it another whack still no joy![Icon No](https://www.jaguarforums.com/forum/images/smilies/icon_no.gif)
Any suggestions, I thought of heat but the bumper is near ...
Any tips recommended
I know space is tight, but, if you can get a G clamp and tighten to break the seal, then turn x degrees and tighten again. Repeat until loose? I tried to get the dp off the underfloor cat while both were off the car. I had to stand on them at the union, flip it over and stand on it again. Eventually after much repetition they came apart.
Car-Nut (04-06-2011)
As a few took the time ot chip in I thought I'd post pics of yesterdays tinkering on the X330 ![Wink](https://www.jaguarforums.com/forum/images/smilies/wink.gif)
![Name: DSCF4432.jpg
Size: 82.2 KB](https://www.jaguarforums.com/forum/attachments/xj-xj6-xjr6-x300-26/172953d1501289121-exhaust-tips-again-dscf4432.jpg)
![Name: DSCF4433.jpg
Size: 59.3 KB](https://www.jaguarforums.com/forum/attachments/xj-xj6-xjr6-x300-26/172954d1501289121-exhaust-tips-again-dscf4433.jpg)
![Name: DSCF4437.jpg
Size: 62.4 KB](https://www.jaguarforums.com/forum/attachments/xj-xj6-xjr6-x300-26/172955d1501289121-exhaust-tips-again-dscf4437.jpg)
![Name: DSCF4439.jpg
Size: 101.4 KB](https://www.jaguarforums.com/forum/attachments/xj-xj6-xjr6-x300-26/172956d1501289121-exhaust-tips-again-dscf4439.jpg)
Halfway there:
![Name: DSCF4440.jpg
Size: 142.2 KB](https://www.jaguarforums.com/forum/attachments/xj-xj6-xjr6-x300-26/172957d1501289121-exhaust-tips-again-dscf4440.jpg)
These wont be going on eBay![Icon No](https://www.jaguarforums.com/forum/images/smilies/icon_no.gif)
![Name: DSCF4447.jpg
Size: 197.3 KB](https://www.jaguarforums.com/forum/attachments/xj-xj6-xjr6-x300-26/172958d1501289121-exhaust-tips-again-dscf4447.jpg)
Close up:
![Name: DSCF4448.jpg
Size: 64.7 KB](https://www.jaguarforums.com/forum/attachments/xj-xj6-xjr6-x300-26/172959d1501289121-exhaust-tips-again-dscf4448.jpg)
Im not over all happy with the quality of the tips but they are better than what was on, also the fitting idea was ugly in my ideas it was 3 U brackets which were tightened on to the exhaust by the bolt, I dumped the the U's and just used the bolts, I still believe the bolts supplied ate too long. I will be changing them, also I will look out for a better quality tip.
I am doing another back-end upgrade next week(I'm not the first to do it but I'll post some pics anyway)
Just preiwing the post, my rear number plate also needs straightening
Halfway there:
Close up:
![Icon Shrug](https://www.jaguarforums.com/forum/images/smilies/icon_shrug.gif)
mikiep
12-20-2019 07:37 PM
FS[SouthWest]: Adamesh X350 Exhaust Tips
XJ8JR
10-02-2015 12:13 AM
baskervillema
10-01-2015 06:43 PM
