exhaust upgrades?
This is a Quicksilver system with a 5 dgree ignition advance Andy bracket on a normally asperated 4.0 liter
He had problems with proper lenth between LWB and SWB models when ordering
60 mm is the pipe diameter at point X , single crossover pipe after the first catss
I think it's the same measure at the downpipe donut gasket point as 2 banks
You have to be careful on assembly at the downpipe gasket flange as the 4 down pointing studs can damage the seal flange , this effects engine regulation , runs rich
i tried it and ended up adding some generic smaller diameter straight-through rear mufflers - it gives a bit more volume, but no drone.
simply performance has some stainless mufflers, but i haven't tried the rear boxes - i have the over axle ones, and they didn't change the sound much compared to stock.
Jaguar XJ6 Quicksilver Exhaust - YouTube
I echo (no pun intended) the notes above about keeping back boxes. I have two stock back boxes and straight piped everything else up to the cats, and it makes for a great deep exhaust note at full throttle while being pretty tolerable during normal driving. You could probably get a local custom exhaust shop to cut out the forward mufflers and replace them with just straight pipes but keep the back boxes intact.
Parker 7 (05-17-2023)
labcoatguy
06-10-2021 06:40 PM
98intrigue
08-05-2016 03:29 PM
