False low coolant light
My car shows that it's got it low coolant. But I checked the Overflow and it's full. Where is the coolant sensor in could it be faulty. This is on the xj6. I did have a low coolant issue a while back but I get that repaired and it's not leaking anywhere. Any ideas? If anything I probably got a little bit too much coolant.
Also be aware that there is a small, donut shaped float inside the tank. If the tank was low or empty for a repair, that float can get stuck at the bottom position even after refilling which would give a low coolant light.
The float goes around the pin of the sensor, although it is enclosed by the tank. It is white and can be seen with a flashlight from the opening. A long screwdriver can free it up so it floats again. Hopefully, a cost-free fix either way.
Cafcpete (11-26-2019)
