Fan Assembly MNC4270AC
ALL sedan fan assys from 1993 to 2003 are the same!!!!!!!!!!!!!!!!!!!!!!!!!!
Individual motor/fans are available used or you can pay for NEW if you wish.
There were several parts suppliers on the interweb selling reman individual fans.
I just get used fans and install them on the shroud when one goes bad.
Jaguar sells the RAD FAN as an ASSY!!!!
bob
bob
EZDriver (04-16-2016)
I got a used fan assembly off of ebay for $149. and installed it this morning. It was from an X308 and the mounting bushings are thicker, so I had to go get two new bolts that were about a quarter of an inch longer. Otherwise it would have taken me 15 minutes to replace it. Much better than paying $850 for a new one.
With all due respect since I get way more good advice from you than you get from me, the bushing mounts appeared to be pressed in and it seemed a lot easier to get a couple of longer bolts than trying to extract old bushings from brittle old plastic. So i bought the bolts and got on with it:-)
Good answer.
The rubber mounts are held in a slot in the rubber and then the steel spacer slides in and locks it in. I usually swap the mounts, it is just a little quicker than finding the longer bolts.
You can also swap the fans/motors to the 'better' used fan shroud (if one is cracked/damaged/missing the rubber flaps etc.). Only 3 nuts each.
bob
bob
The following 2 users liked this post by motorcarman:
EZDriver (04-16-2016),
overtheatlantic (04-16-2016)
Chuck Schexnayder
02-28-2021 10:27 PM
FS[Western US]: Parting out 1997 XK8 convertible
BobRoy
49
09-18-2016 10:48 AM
Florida_Pilot
04-17-2016 08:56 AM
