Fir tree fastener ktc100020
Hi all, I am hoping someone can point me in the right direction or at the very least offer me the dimensions of an FIR TREE FASTENER FOR FRONT SEAT BACK PANEL KTC100020.
I know these are no longer manufactured and the only places I've found, that have them are International. The last quote I received was about $15 per fastener after you added in postage. Ideally, it would be great if someone had the exact dimensions of one so I could source a "Close Enough" substitute locally.
Received 13,006 Likes
Hi Mikey,
Could you pull the back off your other seat to check the dimensions of the fastener? If all you have is the hole or slot into which it fits, you can probably estimate the size you need. Our local NAPA store stocks a wide variety of plastic fasteners and I've often found something that will work. You may have to buy a few different sizes to test-fit, but you'll get them for around $1.00 each.
Cheers,
Don
Cheers,
Don
AD2014 (03-14-2021)
