Flasher Unit
Old 12-30-2010, 02:45 PM
Simprof's Avatar
Default Flasher Unit
I have a 1997 XJR does anyone know where the flasher unit is located on this car.
Old 01-07-2011, 11:55 AM
Alas, you have no flasher in your 1997. That function is provided by the body processor, it takes the switch inputs and flashes the appropriate lamps accordingly.
Old 01-07-2011, 02:48 PM
Simprof's Avatar
Okay that;s great to know my next question would then be if one bulb goes out on one side do you loose them all (on that side that is) as mine are all out and I have checked the bulbs and they seem okay,,
Old 01-07-2011, 03:24 PM
No, one bulb burned out will not affect the others. However, if one bulb's circuit is SHORTED, the body processor will shut them all down for it's own protection. The short could be a bulb itself, or a chafed or pinched wire.
Old 01-07-2011, 04:27 PM
Simprof's Avatar
where would you start? take one bulb out at a time then try the flasher? Left turn is good it only does this only on the right turn..
Old 01-08-2011, 05:38 AM
panchostatus's Avatar
fuse perhaps?
+1 on the possible exposed wiring
Old 01-08-2011, 12:03 PM
Simprof's Avatar
I may be looking at the wrong schematic but I don't see any fuse just for the right side indicators. Like I said the left side works fine it's just the right turn signals that don't. I have not had the time to check the front and side bulbs yet but the rear is fine, it don't work but it;s fine(bulb) I hope it's not the module that's gone..
Old 01-09-2011, 02:02 PM
Now, see, here's where I get into trouble for trying to remember all the car lines and shoot from the hip.
Attached is the pertinant wiring information that should help get you on the right track. On your 1997 model the direction indicators are NOT actually driven directly by the BPM as I said before. There is a lamp control module in the trunk with seperate power feeds for each side.
My humble apologies.
Good luck!
File Type: pdf
Simprof (01-09-2011)
Old 01-09-2011, 02:29 PM
Simprof's Avatar
Thumbs up
Thanks XJRGuy I had noticed that on the drawing but didn't now where to look for the lamp module now I know.. I also noticed that each has a
Solenoid so will take a look at your PDF and hopfully get it sorted, Thanks again.
Old 04-18-2013, 04:21 PM
Atco's Avatar
Default Jaguar X300 Direction Turn Indicator LHS failure
Please see my new thread title as above. You may have sorted your problem by now. Mine was sorted last evening after weeks of trying to find it!. On Fig 09.4 the fused supply comes in at figures 12 & 34 in square boxes. See Fig 01.2 Heel board fuse boxes.
King Charles
10-16-2015 01:25 AM
inactualis
10-02-2015 11:13 AM
Nic1635
10-02-2015 01:30 AM
Lawrence
XJ40 ( XJ81 )
10-01-2015 08:36 AM
Quick Reply: Flasher Unit
