Flushing 1997 XJ6/X300 Pwr. Steering: How to disable ignition?
May be pull the fuel pump relay located in the trunk? and btw im not sure what your trying to do, for ps flush you dont really need to disable the ignition or anything
I was also thinking about renewing my power steering fluid. I think I read somewhere that's it's simply a matter of opening the bottom end of the reservoir hose and drain and refill.
Could I also use a pump with a hose to suck it out or does that create any issues? It's a bit less of a mess that way...
Sorry for jumping in on this thread with a new question but maybe someone knows the answer to our related questions
Castrol Atf Dex IIII | Castrol Australia | Castrol Automatic Transmission Fluids (ATF) | Castrol? Australia | Car - Motor Oil & Lubricants | Castrol Australia | Products | Castrol Australia | Castrol? Engine Oil & Lubricants - Castrol? Australia
Robert Grisar
05-28-2017 01:53 PM
The Coypu
03-29-2017 09:35 PM
FS[MidAtlantic]: Stunning 86 Vanden Plas with only 46K
thedugger1
03-28-2017 05:54 AM
