Front Left Chatter
You can get the bushing from a local auto parts store. Since it is a good bit of work to replace (you need to remove the whole shock), you may want to consider replacing both of the front shocks. At 125,000 miles, my bushings were mostly gone, so I decided to go ahead and replace the shocks too. I'm sure there is a write up in the FAQ section.
yeh, i jacked the drivers side wheel off the ground, and the top mount foam bushing is deteriorated. I guess that is whats chattering when i hit a bump. the round metal bushing cap on top of the shock under the car not having cushion! How hard is it to take off the shock to replace the bushing? Can i make a rubber bushing, cut it and slide it on there just to take away the chatter? Do you have to realign the front end after shock replacement?
aholbro1
08-05-2021 05:02 AM
al_roethlisberger
09-09-2015 09:14 PM
Tar
09-06-2015 11:24 AM
