Front shock bushing assembly order
Somebody has already replaced the front upper shock bushings,but is kinda does not look right.
Top of the shock is the steal #1 washer-#2rubber bushing-#3steal washer,the bolt goes through the shock tower then it is another rubber bushing then washer then the nut.
Is that the correct order? Most I have installed before was where the rubber bushing was bottom of the shock tower then the top rubber and steal washer under the nut. Confusing?
Here's a link to the parts diagram for the front shock which will probably help.
Road Spring and Damper-Front - Parts For XJ Series from (V)720125 to (V)812255 (X300) | Jaguar Heritage Parts UK
Skarre
04-17-2016 02:55 PM
hawaiianjag
02-22-2016 05:49 PM
