Front shocks suggestions
See PDF below page 16 . Notice the difference between the soft X300 Sovereign , Sport , and Vanden Plas and the 2 different and stiffer XJR and V12 shocks . Take notice as to whether the top shock bushing is commonly gap space loose ( I've read easy and cheap fix ) . If you want to rebuild the originals I have a file from Bilstein for the part numbers of the overhaul kit and rebuild instruction videos and you can recharge the shocks service air pressure ( 180 PSI ) at say a motorbike shop with their schrader valve . As to off brand shocks I have no recommendations other then from what I've heard Koni's are a miss match but that may be from getting the wrong hard / soft setup .
Thank , Joe
Thank , Joe
EZDriver (04-17-2017)
The Bilstein "HD" B6 models are for firmer handling like on the XJR, and the "touring" B4 versions are for everything else.
This may be helpful:
https://www.jaguarforums.com/forum/x...-review-79346/
Agreed, and they really aren't that expensive anymore from somewhere like "Shock Warehouse".
al_roethlisberger (04-17-2017)
