Front subframe 'vee' mounts
Somehow I never fail to be amazed by the capacity of this car to throw up one problem after another! Having just crossed the front damper top mounts off of the to-do list, in doing them I've discovered my subframe mounts are shot. They were fine a few weeks ago - I'm sure it's just that the car's determined that the list will never get shorter!
I'm getting too used to sitting in the front wheelarches; In the last few months I've done track rod ends, balljoints, bearings, upper wishbone bushes, shock mounts, as well as all of the brakes (inc. calipers)!
So apart from the obvious (and rather worrying) rusted-in-bolt nightmare that may or may not occur, is the process straightforward enough?
That's definitely the nicer option! I'm getting there though - & it's really the only option for me as I need the car to be on the road pretty much uninterrupted...
That's true... now contemplating what exactly needs to be separated to replace these! Is the easiest way to unbolt the mounts and raise the body, leaving the subframe & engine on the ground? Is there sufficient play to make that work? Do you need to undo the shocks from the body? Gearbox mounts?
+1
The important thing is:
1. to support the weight of the body (axle stands under the front jacking points is a good choice.
2. support the weight of the engine
3. avoid crunching the fan into the radiator
Lacking an engine crane or an engine support bracket at the time, I used this unusual approach to support the engine:
![Front subframe 'vee' mounts-01-sump-replacement-engine-supported.jpg](https://www.jaguarforums.com/forum/attachments/xj-xj6-xjr6-x300-26/64085d1480970486t-front-subframe-vee-mounts-01-sump-replacement-engine-supported.jpg)
In this instance it was to replace the engine oil sump so a little extra 'insurance' was needed!
Jsquared (02-13-2024)
The reverse was a complete PITA, but at least I have a freshly painted subframe, wishbones and all new bushes.
Now for the back end!
Ziggy (12-04-2013)
You do have to disconnect the Shocks at the top (and it's a lot easier to manoeuvre the suspension assembly if they are removed) but don't need to remove the springs if your are dropping the front suspension out:
Attachment 64185
They remain compressed between the Spring Pan and the Upper Wishbone.
Attachment 64185
Of course! I hadn't originally contemplated needing to compress the springs - glad to see that I don't actually have to!
Now other than the engine potentially hitting the rad (I need to do the rad mounts anyway, so that can just come out!), is it too optimistic to hope that I might not need to separate the engine from the subframe either???
When I did the shock mounts, the shot subframe mounts allowed the subframe to drop a bit (confirming that they are indeed shot!). I'm now wondering how far it could 'drop' if the subframe mounts (and shocks) were unbolted and the body jacked up, leaving the wheels on the floor...
Somebody tell me what I'm missing?!
I had heard people say that you can slide them out, but in my experience access to the subframe/vmount bolts is tight and they might be hard to get out. The top flange of the vmount also has stubs on the bolt holes which go into the body, from memory they where about an inch long.
If it wasn't for the 'stubs' that stick up, it would surely be relatively simple (again if the bolts come out) - you wouldn't need to create much clearance then...
![Front subframe 'vee' mounts-crossmember.jpg](https://www.jaguarforums.com/forum/attachments/xj-xj6-xjr6-x300-26/64683d1480970598t-front-subframe-vee-mounts-crossmember.jpg)
These are the problem. The Cross Beam doesn't drop sufficiently to allow them to clear.
A timber wedge between the body and the Cross Beam makes it just possible if you are in a desperate hurry.
Remember, if the Vee Mounts have split apart it's a lot easier to get the old ones out than it is to get the new ones in!
1964Daimler
09-09-2015 11:28 AM
