Front Suspension Update (*a few questions*)
Old 01-20-2014 | 09:18 PM
vandenplas408's Avatar
Default Front Suspension Update (*a few questions*)
So i have all new parts
installed
Front Sensen shocks
2 top shock bushing
stabilizing bar links
stabilizing bushings
sitting in box
lower shock bushing
4 top control arm(wishbone) bushing
2 Big lower control arm(wishbone) bushing
2 Med lower control arm(wishbone) bushing
2 top ball joints
2 lower ball joints
2 outer tie rod ends
I Need these parts and tools before i install everything.
Rack N Pinion ( any one know a good source for this?)
all power steering hoses ( there are 4?)
power steering Pump ( autozone is BEST DEAL $170 life time warranty)
all spring ban bolts ( what size are these?)
left and right engine mount
I am making a tool alleng suggested to me for removing the springs
i cut a 36' steel rod into two pieces 20' and 16'
i need to drill a whole into it and maybe weld the small part that goes threw it ?? (allen??)
can i make a tool for removing the bushingS?
a long bolt with 2 nuts and washers. just make a huge pipe so bushing can slide into it. and on other side a socket to push the bushing out.
think it will work or any ideas on a bushing removal tool?
a cheap torq wrench that can do like that covers 1nm -40nm atleast?
like always ill make a detailed DIY pic tutorial for you guys
just help me out with this info
The following 2 users liked this post by vandenplas408:
4litre (01-20-2014), BigBossRadio (03-19-2014)
Old 01-20-2014 | 10:04 PM
4litre's Avatar
I was looking around for a steering pump re-build kit and I found nothing, they seem to stop at 1994??!!! SMH!!!...The Autozone deal may have to suffice for that it seems to be the cheapest too...
Take the steering hoses off and find a hydraulic shop near you, call them and get a quote for them to make you new ones so they can use the original fittings...and ask them about rebuilding your steering rack too...it's what they do and I'm sure it will be WAY cheaper than buying the original bits...
See and shop around for your mounts on Ebay and grab a good deal....1997 jaguar xj6 in Motor Mounts | eBay
I'm looking around for the best way to remove the control arm bushings and I can only think of using a hack saw blade to do so...if you have OEM style, I'd just take to shop and have press them in...But then again check the link to see how to get it done using urethane roller skates (I like this idea ) ...it's from the X308 forum but, you get the general idea....https://www.jaguarforums.com/forum/x...004-xj8-94229/
Looking forward to see it work!
See vid for home made tool for bushings...
Or this one...
The following 2 users liked this post by 4litre:
BigBossRadio (03-19-2014), panagiotis (08-21-2014)
Old 01-20-2014 | 10:18 PM
4litre's Avatar
Old 01-21-2014 | 01:38 AM
AllanG's Avatar
You can get a rebuilt rack from a number of places, try Coventry West (about $245 net of the core charge)
Yes there are 4 hoses, be sure you need to replace them though as they are pricey. The high pressure hoses are north of $120 each!
The spring pan bolts are M8 x 16mm I believe.
16" is pushing it, 18" is better. You don't need to weld the pin in, just make it a tight fit and add a bit of glue. The pin does not take any side load so won't come out but it will eventually bend a bit so you will have to knock it out and replace it. Very easy.
Yes you can make a tool using a rod and sockets etc. If you have access to a shop press though I would recommend it. I just did all the front bushings on my XJ6 and XJS and it only took an hour to do all of them.
If you do make a tool, be careful sizing the sockets as some of the bushes have quite a thin wall. If your socket is too small it will just push against the rubber and if it's slightly too big will jam in the bore.
The only bush that needs a slightly different approach is the lower front wishbone bush. You can't use a socket as there is nothing for it to purchase on. You will need to cut off two edges of the 'brim' of the bush and then use something to push against the exposed edges of the wishbone to remove the bush.
You can get a cheap torque wrench with a 20-200 inch pounds range from Harbor Freight that'll run about $10-15 on sale.
Looks like you have a fun weekend lined up
Old 01-21-2014 | 10:32 AM
Yah the high pressure one is $100 . And I found a hose from Res to cooler and another from cooler to something else. Each $40.
Can't find the fourth hose. But all of them are cracked. My radiator hoses aren't in good shape either but aren't leaking. My power steering fluid goes empty after 4 days. Then I have to Re fill it.
Every hoses is cracked I double check and the rack n pinion inner tie rods are done and its leaking from the seal. Sucks ***
BigBossRadio (03-02-2014)
Old 01-22-2014 | 12:43 PM
What drill bit size did you use for making the top hole for the tool for springs
Old 01-22-2014 | 02:50 PM
AllanG's Avatar
If you are using an 8mm pin, you could use a 5/16" drill bit and then just drift the pin in. If you are using a 5/16" threaded rod as the cross pin, you could use a 19/64" bit and then tap the hole for 5/16".
Old 01-22-2014 | 04:37 PM
manwich66's Avatar
Default Front end tip
Hi guys,I just did this job on my wifes car,check the xj40 section on the thread "bilstien or KYB",and i posted the pics and such.My homemade tool is still working for me.
Cheers,Jim
The following 2 users liked this post by manwich66:
4litre (01-22-2014), Lawrence (03-25-2014)
Old 01-28-2014 | 01:55 PM
Got the left and right motor mounts for $57 total !!
Now to get the rest and finish making the tool allen suggested
I got it cut but drilling is a bitch lol
Old 03-18-2014 | 02:23 PM
sjc1997xj6's Avatar
How are your Sensen shocks holding up and performing? I recently installed a set.
Old 03-18-2014 | 07:22 PM
Time-Pilot's Avatar
Power steering rebuild kit is about $10 from most online sources. Takes only a few mins to do.
Jaguar XJ6 XJ40 Vanden Plas 88 94 Power Steering Repair Kit AEU2787 | eBay
Old 04-20-2017 | 10:39 AM
shocks are still on and working
need replace soon
trosty
26
12-18-2022 07:40 PM
Mugatu
22
06-23-2020 02:50 PM
daverb
09-05-2015 01:53 PM
bdboyle
09-04-2015 07:16 AM
arnoldmilk
09-03-2015 08:42 PM
