front wheel spindle nut torque spec
Old 11-16-2009 | 09:02 AM
Doug's Avatar
Originally Posted by hennebear
looking for the tourque spec on a 96 vdp front wheel spindle. Also advise on changing grease seal. thanks.
There is no torque spec for the spindle nut. Tighten the nut enough to ensure the bearings are seated, loosen the adjustment, and then take it down again to *just* achieve zero free play as you wiggle the brake disc by hand.....or as close as you can get.
The seals are a real bear in my experience. They fit onto the spindle, not onto the hub. A piece of PCV pipe is a helpful DIY installer tool.
I have vowed to never replace them again unless there was a clear sign that they were leaking.
Others will chime in
Old 12-26-2009 | 03:36 AM
panchostatus's Avatar
I'd rather change a head gasket on a taurus than replace the grease seals for the front hubs.
I'm kidding of course, but you get the idea.
Old 01-08-2012 | 04:12 PM
alex0866's Avatar
If you put the new grease seal in hot water for a couple of minutes and then a little grease on the stub axle it'll go on with a good hard push. need very strong thumbs though..... good luck!
hunter34
19
09-15-2022 12:09 AM
PMKimpton
08-03-2019 09:22 PM
jdzubas
10-04-2015 10:14 AM
al_roethlisberger
09-11-2015 11:04 PM
prettydaim
09-04-2015 10:13 AM
Quick Reply: front wheel spindle nut torque spec
