frozen radio
Guest
Posts: n/a
Try the 'reboot' method. Disconnect the + battery cable for about 5 minutes. Touch the + cable to the negative terminal for just a second before reattaching it to the battery. Reattach the + cable to the battery. This will reset anything that has memory, so any memory dependant functions must be reset. This got my neighbor's radio working again.
Received 2,192 Likes
Guest
Posts: n/a
It seems really strange to me that 2 identical radios would have the exact same 'frozen' problem. I believe I have the 'code' from Jaguar but the radio doesn't ask for a code. Antenna goes up and down when I turn the ignition on and off, but as I said the radio just 'freezes' usually on, and you can't change anything, volume, station, etc. There must be something in the car, not in the (2!) radios causing this!
Guest
Posts: n/a
Sorry to see no one has resolved this - although it does give some pressure to replace the system. I have been having the same problem on my 1997 XJ6, with the radio locking up for periods of time then becoming usable again. I have not been able to correlate its behavior with anything.
I will try the battery disconnect procedure - although this was done once before and it lasted three months or so before the problem came back.
I have used the "reboot" procedure in the past on my 1990 BMW 735, but have left the terminal leads connected together for up to half an hour or longer. It usually tends to remove any "bad" memories and one of the more noticeable improvements is that of a smoother gear change in automatics. It's a procedure that sometimes has to be repeated, as the management system tends to "remember" the cars old bad habits again after a while. Costs nothing and worth a look see. On the issue of a frozen radio, I also have this problem on my recently purchased 1997 x300, only that it's frozen off. Dead as a dodo, although it has power and an earth, as does the antenna. I keep reading about a (brown) radio relay, but despite numerous searches cant locate it. Some posts suggest that it lurks behind the glove box, others mention behind the drivers kick panel at the right side of the steering wheel. I have searched both but to no avail, so, does anybody, pleeeeeaaasseeeeeee have a clear, exact location for this mystery item? many thanks
Received 10,916 Likes
No codes for US market 1996 X300 XJ6 ?
That's good news.
I'm thinking of doing a hard reset.
The radios crap anyhow.
I can't see how I'm gonna find another stereo to fit that shape of an opening, though.
Any ideas?
That's good news.
Any ideas?
