Fuel Cap Pressure?
Hey Lads,
Maybe a dumb question but I just never noticed before.
Was just checking something on my gas cap and when I released it there was a pretty noticeable pressure noise. Couldn't tell if it was sucking or blowing but I suspect sucking from vacuum in the fuel tank.
I just wanted to check with you guys that some level of suction noise is normal?
It just struck me this morning that if the gas cap had failed and the tank couldn't balance to atmospheric, the fuel could get starved to the engine.
Bernie
Bernie
mine doesn't, never has. The vent/evap system should prevent any "whooshing" IF functioning properly (known problem in Jaguars is a failed Rochester valve) properly operating vent/evap system should prevent vacuum pull in on tank under consumption and prevent pressure build up under heating of fuel. Think of a sealed can of gas in your driveway as it heats up in the sun and "swells" the can. Undesirable in cars, if your hearing hissing or wooshing the system is not working up to snuff.
8pockets8
02-21-2016 07:02 PM
