fuel gauge not working well
on my 1995 xjr the fuel gauge barely ever works. it seems to start working when my tanks below half full but only some times and then stops working again completely. the previouse owner said he used some fuel system cleaner in the tank and it started working again. im not sure if i believe this. is the any adverse effects of using a fuel system cleaner like 3ms version? thanks.
Dayn
Dayn
I had an intermittent problem with my fuel gauge also. Knew it was due to a dirty wiper assembly so I just changed the sender unit in the tank. No big deal. Got a new sender from Motorcars Ltd in Houstion and waited until the tank was down around a quarter full. You have good access to the tank from the trunk after you remove the trunk lining. Spin the retainer ring and out with the old one and in with the new one. Actually one of the easiest jobs I have done on the car.
EZDriver 95 XJ6
EZDriver 95 XJ6
The fuel level sender in the tank is most likely the culprit. There were many updates on them over the years. Jag stopped using that design in 2001. Open the trunk lid and peel back the carpet covering the fuel tank. Dead center is a white circle with two wires. That is the sending unit. I recommend making sure the fuel level is below 1/2 tank (preferably near empty). Get a sender and rubber gasket. Tap the locking ring gently counter-clockwise to release the sender. Make a note of which way the wires are going to the sender and remove them. Remove the sender from the tank. Replaced the rubber gasket and install the new sender. Tighten the locking ring clockwise until the tabs stop its movement. A good tight seal here is very important. Reconnect the wires and check the dash for an accurate reading.
On a similar note, one of my older Jags would read zero when it got to 3/4 full. When it dropped below that point, it would go back to reading properly. Funny sometimes the stuff that happens.
The following 5 users liked this post by BlackX300VDP:
Beelzebub422 (04-26-2022),
DevilDog (07-20-2014),
epereira (07-27-2014),
Kleman (02-22-2015),
panagiotis (07-22-2014)
Does the battery need to be disconnected for this procedure? I wouldn't think so but wanted to make sure before starting.
EDIT: Never mind, found the post I remembered seeing from before with the info I needed. Battery disconnected, no radio code needed since NA model.
I suggest you make sure the tsnk is very close to empty or fuel will flow in large volume from the opening and you know how volatile and explosive fuel is ! Also, if you can, park the car facing downhill so whatever fuel is in the tank it will be further away from the
opening.
opening.
Job done, 20 minutes total including disconnecting the battery. So nice to have clear dash with no check engine light and low fuel warning
Another 1-2cm of fuel in the tank and it would have spilled out even with the nose pointed downhill
Fill-up afterwards revealed around 8 gallons left in the tank at time of repair.
wayland (04-14-2016)
I would park on a slope if possible with the front of the car pointing downwards with the gauge reading at the most half full (1/4 should be good). Depending on the degree of the slope it should be more than enough to be able to remove the fuel gauge without spilling any fuel
epereira (07-20-2014)
