fuel pump relay demon
Lady Penelope (08-01-2018)
The ECU provides a ground to command the relay closed . The relay # 3 on the irow the fuel pump relay is on gets it's ground command from the ignition switch . The factory wiring configuration has the ECU provided command ground passing through the troublesome Papa Indy 61 connector .See page 19 of the file below .
bliving7 (08-01-2018)
Lady Penelope (08-02-2018)
The following 3 users liked this post by bliving7:
tokoloshi
11-13-2015 10:48 AM
