Fuel sender shows 3/4 full when tank full
If you remove the panel at the front of the trunk, you will see the sender unit right in the centre of the tank facing you. There is a locking ring that needs to be turned to the left to remove. Be careful not to damage it! Sometimes a long screw driver works, but I have been known to use a punch to carefully "persuade" it to turn. I would recommend you run the tank down to as low as you can before removing the sender, and remember fuel is explosive! Use great care when handling gasoline. I have never been able to simply clean a sender unit, and the cost is not very prohibitive to simply replace the whole unit and gasket and be done with it for another 200'000 Kms. Just be sure to snug it in well when tightening the lock ring. And make sure it is spotlessly clean.
Not a big job by any means. Have fun!
hen555
09-07-2015 11:13 PM
deanh
09-06-2015 08:20 PM
