Furl injectors for a 96 Jag XJ6/300
hello everyone, I own a 1996 XJ6/300 and I hear a ticking noise that has been getting louder over time. I took it to the jaguar tech over here and he said it was my fuel injectors. Now I can get all 6 injectors for around 650-700 bucks or so, but I wanted to know before I actually do all of that, should I get the injectors cleaned and or remanufactured? Or just go brand new with them to stop the ticking noise. And also, what is the labor time on installing 6 fuel injectors plus the orings... thanks.
Received 2,191 Likes
theyre normally noisy at idle and alittle about till the clicks become fast enough its a continous sound. If theyre louder than normal but still work fine without issue, then use the button on the radio to tune them out
Please look at this site before you spend that much money on 6 injectors. These are standard Bosch style, so I do belive GM TPI/LT1 and some others will cross reference with the XJ series motors. I am just learning my Jag but I have been a EFI Chevy guy for a long time. I can't promise 100% but I think you will be pleasently suprised if you lay a TPI injector.....Mustang GT or Corvette injector next to ours.
http://www.fiveomotorsport.com/Injector_SetsENGLAND.asp
Brian Felts
Brian Felts
Charlene n John
09-28-2015 06:01 AM
