gas/throttle sticking all the time
I've did some searching but found nothing too conclusive. When driving (especially in the cold), the gas gets stuck sometimes. Not good and can be scary in the right situations. I have to tap the gas once or several times to get it to unjam. Any tips on how to find the issue?
It would seem I'm missing some very key parts in my throttle linkage...excuse if I misuse terminology. I am indeed missing the return spring and the arm that the spring attaches to on the butterfly side of the works....obviously any bolt or whatever that would attach said arm as well. Can I find these parts somewhere? This explains a whole lot on why my car is dangerous.
Thanks in advance!!!!
take a look at throttle bodies for your car on ebay, there are plenty of detailed pics and look to see if you are missing any parts. I dont think your tb came apart, once together all the bits stay put. I tried to download pics for you but was unable to. pretty much think you just need to clean it as they tend to get dirty and stick, common problem.
your throttle body has two springs on it, one for the throttle plate and the other for the accelerator cable. If you only have one then I guess it broke and fell off, i never seen that before but anything is possible. Its an easy fix, just remove throttle body, dissemble and replace the spring. I believe your cars tb is easily to get at because it has no supercharger, the sc version would be a big pain to get at. take a look at the pic and tell me which spring is missing. There is a complete tb on ebay for $70.00, minus sensors, take a look.
Dan is probably thinking of the old method of a return spring hooked onto a stud on the throttle arm and the other end attached elsewhere on the engine. That hasn't been done in quite a few years. The springs are integral to the throttle body.
Here's a pic.
![](https://www.jaguarforums.com/forum/attachments/xj-xj6-xjr6-x300-26/34064-gas-throttle-sticking-all-time-xj6tb_zpsfbf0eaff.jpg?dateline=1361252111)
I've indicated the two different springs that should be there. It is rare for them to break, but it has happened to me (on other makes of cars). If it did break, the spring would still be on the shaft unless someone has pulled it off. Without pulling the throttle body apart, it takes quite a bit of unwinding to remove.
What is most likely causing your throttle to stick is the carbon gunk built up in the bore, as it is in this picture. Pay a visit to your local parts house and get some throttle body cleaner. You may have to use an old tooth brush to get some stubborn deposits off.
DO NOT use carburetor cleaner, as that will damage the sensors if it comes in contact with them.
Here's a pic.
Here's a pic.
Here's a pic.
Now to figure out how to take the slack out of the cable.....
Wolfy
05-28-2024 08:06 AM
