Good ole key fob
Weak batteries wreak havoc on my car’s auto locking doors.
However, while we got you, what seems to be the problem? Total no locking with the remote? Manually locking with key works? On all doors? What about when in the car and manually locking, does it work? On all doors?
Is the problem only when using the fob? Locking and unlocking are both not working the same way? Does the cat chirp when pressing the fob button, so that we know the car understands the signal?
Ok. I think we’ve eliminated the battery. (Only because you’re not experiencing any issues locking the doors other ways. A weak battery would have wonky effects even when locking doors without using the FOB)
There is probably a relay or security module that’s causing the problem. If it never worked, it may have been deactivated. A dealer or someone with a WDS or PDU could probably reactivate it, if it was indeed deactivated. I’m not absolutely sure that feature could be deactivated though....
Can you tell me how the car responds when you do press the fob button?
Chris starko
05-18-2016 09:10 AM
