h&r wheel spacers
kk got it. wheels are.
made by koya , aluminium
rim width = 8J
diameter = 19
offset = 35
these are the wheels. that link is not mine just one i found on google.
http://www.gumtree.com.au/s-ad/baulk...den/1021169596
rim width = 8J
diameter = 19
offset = 35
rim width = 8J
diameter = 19
offset = 35
Koya Inox "IMAGINE" (1 only) 5/120 HS 35+ Good Condition, Holden | Wheels, Tyres & Rims | Gumtree Australia The Hills District - Baulkham Hills
rim width = 8J
diameter = 19
offset = 35
225/60 r16 is 676mm, 225/55 r16 is 654mm. Both standard fitment on different X300 variations AFAIK.
235/35 r19 is 647mm - so you can go bigger than that with no probs if you get the offset right first.
245/40 r19 is 679mm
245/35 r19 is 654mm
Got the numbers from behind the spokes on mine. But something doesnt add up cause there is 1" 1/2 , distance. Im not convinced ill like the 32mm spacers or that they will fit without some wheel rub on the fenders. So 25mm would be best imo. Too bad I cant go to a local shop and try various spacers.
Received 9,011 Likes
lickahotskillet
10-18-2015 09:51 AM
lickahotskillet
09-11-2015 07:54 PM
metalmarty
09-11-2015 07:05 AM
