Hard to explain............
Received 12,952 Likes
Another very good possibility, aholbro1! Also, a tire with a separating steel belt or other internal damage can look good but cause vibration.
Like others I suspect your vibration is driveline-related, but a failing fuel pressure regulator could allow the pressure at the fuel rail to fluctuate and lead to uneven cylinder combustion...... I found an OE Bosch FPR for under $100, but other brands are available for as little as $40.
Don
Don
mikiep
12-20-2019 07:37 PM
