Hard reset question
Hard reset question
Trying to get to the bottom of my dead instrument cluster, I read various posts regarding the "hard reset". I am familiar with the concept from ownership of an old 7 series BMW, whereby, both battery terminals were disconnected and hooked togeher, for about 15 minutes. However, posts on here suggest that the negative - lead should be disconnected from the battery and then held onto the positive + battery terminal, with the ignition switched off. Is this correct? A definite answer please, from someone who has actually done this, without frying anything in the process. I am reluctant to send power to earth/ground using this method and want to be sure I have it right. Thanks in advance.
Received 10,916 Likes
Received 2,192 Likes
Hard reset update
What gives?? Any thoughts appreciated.
Well, as a first rather obvious GUESS, I would say the instrument cluster might have crapped out. I have never seen the dashes, but then I have never been looking at the cluster as I reconnected the battery. And I am sure the divide the mileage in half thing is not a common occurance or someone would have mentioned it before. If the module wa dying, your symptoms could surely be the result.
Crazy dash
Thanks again and watch this space.
Update of sorts.
I intend to check the ignition swich/ wiring and connector beneath the steering column shroud, as an additional (new) situation has developed. The car tends to cut out when driving, if I brake any way hard at all. I still have no radio, which seems to be where my problem started, when it just froze up and refused to switch off, even with the ignition off and the key removed. Disconnecting the negative battery lead sorted that out, but left me with a dead dash. So, I supposer another look see at the relays wouldn't go astray. I also switched between miles and Kms with no effect.
Thanks again for the input, a problem isn't so bad with others chipping in!
Updates will follow.
sogood .... I can't offer any help with your problem but I just had to comment on something that you said/typed.
You typed .... Thanks again for the input, a problem isn't so bad with others chipping in!
When I ask for help with a tricky problem, it feels just like a dozen or more guys are leaning over my shoulder as I tinker with the engine. Not only stroking their own chins a d telling me what to do but getting info and hints from each other at the same time as well. It's like magic at times.
trosty
26
12-18-2022 06:40 PM
