Has anyone Refurbished/repaired a power steering pump?
Hi Big Boss,
This might not help you much, but FWIW when I bought my '97 3 years ago, I had a local Jag mech. give it the once-over. He found a minor leak in the PS and he told me the PS pump is integral with the rack, and to refurbish the pump the rack must be removed. Apparently this changed from the XJ40 set up where I understand the pump could be worked on separately.
I'm sure others will either confirm or correct this. Either way I'd also be interested in more views about refurbishing the pump for the long term.
As my leak was very, very minor I decided to try Lucas Stop Leak. The leak virtually disappeared after about 3,000kms. Not sure how long that will last!![Icon Shrug](https://www.jaguarforums.com/forum/images/smilies/icon_shrug.gif)
Cheers,
Cheers,
The following 2 users liked this post by jagent:
BigBossRadio (05-31-2014),
patetonga (06-01-2014)
The following 2 users liked this post by b1mcp:
BigBossRadio (06-01-2014),
VickTrader (12-08-2022)
I don't know of anyone who has successfully rebuilt their own rack with a seal kit, but would seem an effort in futility, even if you had the necessary tools. And @ $200-$400 for a new refurbished assembly, that's the route which pretty much everyone goes. I still need to swap mine out as well, but filling the rack boot with lithium grease, along with running a mix of PS Fluid, and Motor Honey for increased viscosity, has slowed my leak to a negligible level. I haven't been in too much of a hurry because frankly I enjoy the more sporting steering feel that the increased viscosity fluid provides.
Luckily the rack is a faily easy job on our cars. There are only 2 bolts holding the dang thing on! It's a pretty straight forward affair. I strongly suggest using locktite when reinstalling the new rack since, well there are only 2 bolts holding the dang thing on and more than a few have had steering get sloppy on em due to a loosely secured rack.
send me an e mail if you want an original copy of ZF full diagram of racks. in aid of your dismantling and assembling of the whole rack including the servo.
Another common source of a leak is the hoses coming out from under the power steering reservoir
The old hoses deforms from clamp pressure and the leak gets distributed everywhere
You can cut off 1 inch of hose to fresh not crushed hose to hook back up
This would be a good time to replace the old power steering fluid as it starts to cavitate making noise at the pump
The drain / fill process like on a transmission will after 4 or 5 times refresh the fluid toward but not on % 100
This refreshing will also soften the seals in the system and help resolve any leaks in the PS system to a point
The following 2 users liked this post by Parker 7:
Super_JonnyG (01-13-2022),
I no longer have the car, but I’m pretty sure I replaced the hoses and put adjustable clamps on. If I remember correctly, the OE clamps are not adjustable.
SamOscarBrown
01-01-2014 12:41 PM
Rocafella117
04-13-2010 09:56 PM
Rocafella117
01-07-2010 09:59 AM
