Headlight Beam
The lens has come unglued from the reflector bucket, which is a relatively common issue. My RH side low beam did the same.
You can try to glue it back, but its probably easier and more reliable to get a used lens from a salvage yard or eBay. If you try to glue it back together, I'm not sure what to recommend you do to prep or glue it, but it is theoretically do-able.
Used headlights aren't very expensive though, which is the route I went.
I actually did the repair by removing it and applying glue-epoxy glue. This was done today and hopefully all will be fine.
vdpnyc
06-23-2016 10:04 PM
