Headlight Jet cleaners
For those that might have them is there a good way to test them? The manual says that it will spray for every 8 times you spray your windshield. If that is the case is from the time you start your car or from the last time you do it. Also is there a way to test to make sure they even work? I have replaced just about everything.
