headlight swap
there you go mate, not mine, but I know this website has some useful stuff
Jaguar XJ6; Jaguar X300; Jaguar XJ6 3.2 Sport; Miscellaneous notes
i did mine but have to cut plugs off and rewire them
As I recall from a salvage yard, there is a short harness between the headlight buckets and the main harness. I was wondering if the only difference was the headlight end of that harness and perhaps if one installed this short harness from the X308 with the X308 headlights that it may be "plug and play" and not require any wiring modification?
Has anyone checked?
Has anyone checked?
MikeyB10 (05-04-2015)
I have already changed the tail lights for a pair from an xJ8 and besides from adding an extra hole for a globe the XJ8 doesn't have they were a straight changeover and much better.
I was looking at some of the XJ8 and XJ6 short headlight harnesses in photos on line, and it appears that the harness (not bulb) connector may be physically the same (but the XJ6 connector is yellow I think , and the XJ8 version I think is blue).
So it may be possible that these short harnesses are plug-and-play, or the pins could be moved to be plug-and-play versus having to cut wires?
One would have to have a set of XJ6 and a set of XJ8 headlight harnesses to test of course.
Received 2,195 Likes
The connectors are indeed different. I changed mine on the 95 years ago but I adapted a set of HID projectors from a Stype into them instead. WAY better than anything halogen you can slap in them and they have cutoffs so you dont blind people. (something I hate when people just put in HID bulbs IMO should be illegal)
someguywithajag (09-15-2021)
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
