Head's up on X300 coils
#81
Received 10,880 Likes
SNG Barratt USA (01-03-2014)
#82
Hello,
No trouble at all. Ours does indeed have the same black sticker, all be it ours is applied straight![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
I don't have the ability to upload pics here unfortunately due to our server restrictions but feel free to email me and I'll send you some detailed pictures. I currently have 3 units in stock with plenty more available.
Regards
William@SngBarratt.Com
Regards
Do you know if that also applies to coils sold by SNG Barratt UK?
Jonathan
#84
sorry I should have moved much earlier but I haven't, I have to ask TRW Japan asap.
ronbros, they go bad because they are mounted in a hole in a cam cover and exposed in heat all the time. When the inner insulator plastic cracks because of the heat, they die. Plus there seem to be a lot of Chinese made coils in the market, which might be a biggest problem.
#85
Hello Jonathan,
Yes we list the same products across all of our branches. Providing you order the coil designated with a # you will receive the OEM 'Made In Japan' coil.
Be sure to mention JaguarForums and I'm sure they will discount the order
#86
Received 9,010 Likes
Kudos to you SNG Barratt
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
SNG Barratt USA (01-06-2014)
#87
Oddly, when you navigate through the website's menus, it shows the "X300" as "1994-1997 MY", which is incorrect. (or I've been misinformed all this time
#88
Where? Just wondering.
It doesn't matter much, though. In the USA the X300 model run is very definitive: 1995-96-97 "model years". That's it.
Elsewhere in the world, not so much. For some folks the "year" designation is when the car was first sold. For others, the year of manufacture.
This will always be a bit of a bugaboo.
#89
At this URL: SNG Barratt - The Ultimate Jaguar Parts Specialist
No biggy, but I find it odd this is the first Jag Parts place that listed the x300 platform as year models 1994-1997. But as you state, it's not a big deal, cause we know it's 95-97
#90
No biggy, but I find it odd this is the first Jag Parts place that listed the x300 platform as year models 1994-1997. But as you state, it's not a big deal, cause we know it's 95-97![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Silly me, I thought you were referring to something that you saw here on Jaguarforums.com
It also dawned on me that my posting might be interpreted as suggesting your remarks don't matter much. That's not what I meant
This is what comes of posting before my 2nd cup of coffee.
#91
They've mixed up calendar years and model years. MY95 started in September '94. MY97 finished in August '97.
#92
#93
One thing that may be causing premature coil failure. When I bought my car at 65K miles I went in right away to check plugs. Much to my surprise the previous "lug nut" that was in there did not put the coils back with gaskets. No gaskets means higher heat transfer. I also think one should use a grease on the gaskets such as a dielectric. Grease will further insulate the coils from heat as well as reduce the static electricity transfer that causes cam cover electrosis.
#94
Webpage: XJ6 Spark Plug Boss Seal
Here's a link to a forum thread discussing this issue back in 2010:
X300 Camshaft Cover Corrosion
Ah yes, I can see what you mean, that is a brilliant insight.. A form of spark erosion! This is in actual fact is a process we sometimes use in engineering to produce deep slots in metals, say 1mm wide by 20mm deep, for example, beyond the scope of normal cutting tools which would just break if used at these depths due to their fragility.
I have a question for the group:
What about wrapping each coil in some sort of "spark shield" cloth? My knee-jerk thought is to use some HeatShield cloth I've bought from Summit racing (for another project), but it's aluminized, so not sure that's the correct solution.
CobraCloth Webpage: Cobra Heat Shield Cloth | Heatshield Products
#95
On the up side, we don't have a distributor or any HT leads to get wet.
#96
Hello,
Regards
Regards
YAY!
Just got the coil today and am 100% satisfied that it's 'the real thing'
My hat's off to SNG Barratt
SNG Barratt USA (01-10-2014)
#97
Finally they gave me an answer...
It will take a little more for me to be able to start providing the Japanese X300 coils, but I will be able to offer them at £49/$81 including shipping cost from Japan to worldwide.
I can give some discount to multiple purchase(for the shipping will be cheaper when I send several coils together) .
If you are not in hurry and can wait for a month or two until I get in the coils, when you make a reservation and I will give 5% off from the total price.
Again, I guarantee the coils I offer are MADE IN JAPAN.
Hope you guys like this offer...
The following 3 users liked this post by Japthug:
#98
#99
