Heater
Hi every one again
Today I check air heater and its not work. I have 2 jaguars about 1 month only and don't try it before. On both cars air just little warm, I will use heater just in the morning time in the winter time (2 month in the florida). Today 93F (34 c) outside and air blow just little warm. It is should be cold outside to heater begin work? Or I have the problem?
Received 10,952 Likes
Is your temperture gauge showing an "N" reading, indicating the engine if fully warming up? If not the thermostat is probably stuck open....common problem. This will result in weak heater performance.
Next is check check the electric coolant pump that sned coolant to the heater core. They are known to fail. DO you hear/feel it running?
jazzman20014
10-26-2015 04:15 PM
FS[NorthWest]: XJ8 / XJR 3" Mina Gallery Intake Pipe only (For X308)
xjrjag
10-12-2015 03:16 PM
