Heater Core pics for 1997 XJ6?
I was reading about the heater problems and heater core issues with the XJ6? Does anybody have any pics of the heater core to flush? I only saw 2 post on heater cores in the X300 section. I can flush it this weekend but i would like some experienced people to give me some advise. So that it goes smooth....
Thanks so much
jake
Thanks so much
jake
Follow the hoses that come out of the heater solenoid valve and the heater coolant pump. You will see two hoses that connect to two metal tubes that go through the firewall. To back flush the matrix, disconnect the two hoses and hook up a garden hose to the one that goes to the heater valve and a discharge hose to the other. Increase flow slowly, if no flow the core is blocked and not much you can do except remove it which is a pain
jakeperigo (02-13-2014)
rusty37
04-05-2020 07:40 PM
