HELP! 2 broken valve cover bolts stuck in engine!
The cover bolts are hard to find , but I had a problem with one of mine i found out that all of them does not need to be there in the first place ,so I taped out the the threads and torqued the bolt as much I could , never did get tight as it should be so I let it go ,looks great , no leaks at all . I just wanted to share this with you all, Satterfield
