HELP: 4/3/15 Dipstick tube removal from tranny oil pan
Old 04-06-2015, 11:06 PM
SD96XJ6L's Avatar
Default HELP: 4/3/15 Dipstick tube removal from tranny oil pan
I am in the process of dropping my transmission pan to replace some fluid and most importantly the filter.
1997 XJ6
I'm stuck attempting to get the dip stick tube nut off?
Do I just unbolt near manifold and snake the whole thing out?
HELP PLEASE
Old 04-07-2015, 02:04 AM
Nookieman's Avatar
I haven't tried on your car but I believe if you remove any bolts that mount the dipstick tube, what you are left with is a tube that is just shoved Ito the body of the transmission. Gentle twisting and firmly tugging on it should free it.
I would inspect the entire length of the tube before trying too hard to pull it out.
If anyone else has actual experience with this transmission take their advice over mine.
Good luck!
Old 04-07-2015, 01:36 PM
b1mcp's Avatar
You should be able to just remove the nut at the sump and the tube should pull away (Drain fluid first). It is tight but may be you need a bigger spanner. Ideally a Flare Nut Spanner.
Old 04-07-2015, 05:23 PM
SD96XJ6L's Avatar
I figured it out. It's simpler than I thought. Crescent wrench, open, drain, drop pain r&r filter and reverse.
bamforp
08-14-2024 05:36 PM
kelliott
05-31-2022 05:26 PM
aholbro1
08-05-2021 05:02 AM
Daim
11-28-2016 09:28 AM
Dymaxxion
09-04-2015 02:40 PM
Quick Reply: HELP: 4/3/15 Dipstick tube removal from tranny oil pan
