Help with 97 XJ6 emission or fuel system problem
Old 11-20-2016, 02:14 PM
KWalton's Avatar
Question Help with 97 XJ6 emission or fuel system problem
My 97 XJ6 4,000 is having a problem starting, was told it is my IAC motor, it chugs and dies and eventually starts, it runs fine after it starts, but the check engine light is on.
I am going to a parts store to get my error codes. I will update when I have them, in the meantime can anyone link me to more info on how to clean this part or something. I really can't afford the work at a even an after market shop, but I do have some experience working on American cars.
Old 11-20-2016, 02:48 PM
GGG is offline
Received 16,865 Likes on 12,186 Posts
Welcome to the forum KWalton,
I've moved your question from General Tech Help to X300 forum. This is the place to post technical questions about your model.
KWalton (11-20-2016)
Old 11-20-2016, 05:13 PM
Received 8,202 Likes on 4,946 Posts
If you open the throttle (with your foot) while cranking, does the engine start and run?
The IACV only allows significant air when the throttle blade is closed, You can bypass it by holding the throttle open slightly.
Maybe the EGR valve is 'hung-open'?
That will create quite an intake leak.
bob
The following 2 users liked this post by motorcarman:
KWalton (11-20-2016), littlelic69 (11-22-2016)
Old 11-20-2016, 09:00 PM
KWalton's Avatar
Dear Bob,
Yes...if I pump the accelerator several times...but it doesn't always on first try, often it will shudder and croak. I got busy today and didn't get a chance to get to the store for error codes.
Old 11-25-2016, 01:11 AM
KWalton's Avatar
OK, I went O'Riellys and got my error codes.
They were: PO340 Camshaft position sensor; and two others the couldn't define: B30F4? and P13B0?
Old 11-26-2016, 10:14 AM
aholbro1's Avatar
Received 1,643 Likes on 1,068 Posts
Failed camshaft position sensor makes the ECM "guess" as to TDC. Reportedly may have to crank for up to 30 seconds before the computer sorts things out and fires it successfully. After that, running should not be affected. There are threads about the other two codes but they seem a bit mysterious and no one has yet sorted them, from what I've read.
Old 11-26-2016, 10:58 AM
KWalton's Avatar
Ahhh, very cool! That explains why. Thanks for the info. I've explored how to replace the sensor, seems pretty straight forward, however its location isn't, lol. I will replace bracket for it as well since that will probably fail next grrr. Any suggestions on all of it?
Old 11-26-2016, 11:14 AM
b1mcp's Avatar
Make sure you are not confusing the Camshaft Sensor and the Crankshaft Sensor.
Alholbro1 is referring to the Camshaft Sensor. Reading between the lines on your reply you may be thinking of the Crankshaft Sensor.
Old 11-26-2016, 12:03 PM
KWalton's Avatar
Thanks for the picture, and the difference duly noted. I may have been looking for it in wrong spot. ^)
Old 12-02-2016, 05:12 PM
KWalton's Avatar
OK, so the camshaft sensor has zinc been replaced. Still having starting issues. I am sure I read somewhere about messing with the sensor required calibrating something else. Can anyone give me insight?
Old 12-02-2016, 06:27 PM
b1mcp's Avatar
The Cam sensor is used to tell the ECU when Cyl 1 is at TDC. So it needs to be set in the correct position when installed - in the same way as you would align a distributor in days gone by. In fact it's actually installed where the distributor used to be on the older AJ6 engine.
There is a window on the sensor that will show an indicator.
I'm attaching an old "how to" document that I saved many years ago - don't know from where so I can't give the author credit. Hopefully it will explain what you need to do.
File Type: pdf
Old 12-02-2016, 07:18 PM
KWalton's Avatar
Thanks Brendan. My mechanic showed me a burnt circuit board for something else...I'm getting tired of dropping $1000s on this darn car!
