I needed to replace my exhaust gaskets coming from the manifold to the down pipe before the pre-cats. Everything went ok, but when I went to put the EGR tubes back on, one of them will not thread back in and is slightly stripped. ARGH! What do I do? Anyone know of a solution? Thread repair kit? It's a 17mm head the same as the 02 sensors. Any input would be great!
Reason: add pic
Is what you refer to as "stripped" the first thread on the thread nut, or is it the thread in the body? Use a triangle file to clean up the one on the nut. I have no idea for the one in the manifold.
